Rick Graham wrote:
> Dana,
> That works but I would like to be able to select ALL of the objects and have
> them all mask instead of picking one and then having to redo the command for
> 150 more pads. Unless I'm just not getting it yet - which is very possible!
FWIW, once you define an inside mask, you cannot use any other masks
with the surface. Insane, I know, but I had a customer run into that
issue, and it (believe it or not) documented in the help file.
Directly from help:
If you define an inside mask, you cannot use other types of masks on the
same surface.
Jason Hickey
Civil 3D 2007, SP2
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
