It's really not so terrible. It's a matter of preference. I _always_ use
an LTSCALE of what my viewport scale is because then I can see my linetypes
in Model. PSLTSCALE then takes care of Paperspace. For those rare
instances when I have viewports at different scales, I'll use
PSLTSCALE/LTSCALE at 1.
Just a habit I kept from when LDT automatically set LTSCALE to the project
scale. I guess C3D doesn't do this.
"James Wedding" wrote in message
news:4881974@discussion.autodesk.com...
I'm sorry, but that's terrible advice. Most of us plot from layouts at 1:1,
and in that case, PSLTSCALE _should_ be 1, and LTSCALE should be 1 (or
perhaps .75, I understand that's quite popular.)
MHiggins, you didn't tell us if the digitized lines are actually C3D
contours (which I doubt they are since you don't have a surface,) or simply
polylines. Have you checked your polylines for LTGEN? Pick all of the
plines, pull up the Properties dialog box, and look for Linetype Generation
and make sure it is enabled. That will take care of most of the dashes
appear as solids. LTGEN determines how dashes are calculated across a pline,
whether based on node-node distance, or simply on distance along the pline
itself. We've found that LTGEN is almost always best at ON, but there are
some cases where the nodes are VERY important, so you have to turn it off.
HTH!
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006
