Civil 3D Forum
Contour Texts
4 REPLIES 4
windycityengineer
742 Views, 4 Replies
Contour Texts
The contour lines themselves are in model space. The contour texts are in paper space. How do I make the line hide under the  text? I have attached of a similar drawing done by someone else. Any help is greatly appreciated.
Thank you,
WindyCityEngineer
4 REPLIES 4
troma
in reply to: windycityengineer
You are in an unusual situation to have the contour labels in paper space.
However, you could consider using wipeouts, although I generally despise them.  My preffered option would be to use the background mask option in Mtext.
If this text is actually Mtext, you can select them all, go to your properties, and add the background mask. I like a factor  or 1.05, and be sure to select 'Use background color'.mask.png
Mark Green
Working on Civil 3D in Canada
troma
If your text is regular TEXT, not MTEXT, you need to convert it first.  The Express tool will do that, but you have to run it one by one, or it will combine all the labels into one piece of MTEXT.
The attached lisp will convert all the selected regular TEXT into MTEXT, leaving them as separate entities.  Be sure to set the Mtext width to zero after you convert, and then set the background mask.
Mark Green
dgordon
Since we are using civil 3d software why not use the contour lines to create a surface and use C3D contour lables to lable the contour lines.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Joe-Bouza
in reply to: dgordon
Very diplomatic of you , Dan Smiley Wink my thoughts were in other arena's
Your Name
Your Name
Rail Community
