Show only
Search instead for
I am designing a pond and need to create an elevation/area table. How do I create a table that displays even elevations and the area of the contour at that elevation.
I don't know if you are using 2011 but if you are it is super easy. Type in "stagestorage" on the command line and it should become obvious from there.
Use the Stage-Storage Extension to create a Stage-Area table.
Matthew Anderson, PE
