Civil 3D Forum
Contour lines not showing
10 REPLIES 10
Message 1 of 11
Harold_Alberto
3770 Views, 10 Replies
Hi All,
We recently received a LiDAR data in the form of an .asc file.  Brought it fine into Civil 3d.
However, the level data is in mm so levels are showing as 98450 instead of 98.45.  The level ranges from 98450 to 166260.
When I create a surface and set the style to show contours, it only displays contour lines below 100,000.  Is this a limit in Civil 3D or am I missing some setting somewhere?  I'm using the UKIE template btw.
TIA.
Harold
Tags (1)
10 REPLIES 10
Message 2 of 11
in reply to: Harold_Alberto
Change your "Level Of Detail" you can find it under the View Layout tap. Be sure that it is off.
Have a blessed day!
Message 3 of 11
Harold_Alberto
Thank you but I already have it off.
Message 4 of 11
In Toolspace, select the Settings Tab and expand the Surface > Label Styles > Contour and right click the style in use and pick "Edit". From there, under the Layout Tab, look in the Text category to find the Contents Property and click the ellipses in the Value column. When you select that, you will be able to adjust the parameters and precision of the elevation to appear. Click the Properties drop-down in the Properties Tab and select Surface Elevation.
Don't forget to click the Arrow by the Properties drop-down to confirm the recent changes.
I hope that helps.
Cheers,
Mitch
Message 5 of 11
troma
Do you want to deal with it in mm or convert to m?  There have been a few discussion on how to scale x & y but not z; I'm sure you could use a similar method to scale the z by 0.001 without scaling x & y.  Might be better way to go.
Mark Green
Working on Civil 3D in Canada
Message 6 of 11
Harold_Alberto
Thank you Mitch.
I am however not missing contour labels but contour lines above 100000 level.
I think it is a limit in Civil 3D.  In reality a level of 100,000 (m or feet) is way above any ground feature!  🙂
Message 7 of 11
Harold_Alberto
in reply to: troma
Since the LiDAR data is in mm, I don't mind working in mm.  We only need to produce a contour plan for now until we get the GIS data with the right units.
Another option I can think of is to set the Point Cloud style to show 1000 range intervals and trace over.  But that would take time due to the size.
Message 8 of 11
I'm sorry, I must have read the problem too quickly. I thought you were saying you had an issue with not being able to display the contour labels the way you would like to see them.
Message 9 of 11
I am now trying to create a Surface Points to CSV report and will edit the levels from Excel.
Not sure if it would work though, it's a large surface with millions of points.
Message 10 of 11
I'm pretty sure that excell won't accept a million points from a file.    I think it even has problems with 100k points.
Message 11 of 11
Harold_Alberto
I thought so.  Even the report is taking ages.  Guess we have to wait for the correct data.  Smiley Frustrated
Thanks everyone! Smiley Happy
Rail Community
