0 Kudos
Post 1 of 6
Contour Lines not displaying correctly.
1240 Views, 5 Replies
10-16-2012 06:53 AM
What is the easiest way to correct contour lines when they don't display correct?   Adding points, deleting points, switching edges...
See everything circled in orange on attached pdf.
Distinguished Mentor
37 Kudos
Post 2 of 6
Re: Contour Lines not displaying correctly.
10-16-2012 07:00 AM in reply to: SSAuburn
Assuming that is a corridor-related berm you've created, it looks like you have some targeting issues, maybe? Hard to tell.
0 Kudos
Post 3 of 6
10-16-2012 07:02 AM in reply to: castled071049
What do you mean by target issues?
37 Kudos
Post 4 of 6
10-16-2012 07:06 AM in reply to: SSAuburn
For example, in the area marked "Two C Pipes", the contour issues look like the something is amiss, perhaps, with the berm grading back to existing grade? Lots of things can be causing your problem, I'm just guessing at one that might be a cause.
245 Kudos
Post 5 of 6
10-16-2012 07:46 AM in reply to: SSAuburn
If this is an exisitng topo or a feature line or a grading design I would be fixing the breaklines and/or removing the bum shots creating these issues. What I see in your file is what I see in our files when the surveyor used points in the surface for objects sticking out of the gound (or underground) like top of hydrants, top of headwalls, (pipe inverts) etc. or when breaklines are required but are not modeled.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
245 Kudos
Post 6 of 6
10-16-2012 07:48 AM in reply to: jmayo
If you added contours to the surface definition I would make sure that you have the Minimize Flat Areas option checked. This should fix the errant contours going over the flat areas.
John Mayo, PE
IDSP 2014
