Civil 3D Forum
Contour lines display
4 REPLIES 4
1523 Views, 4 Replies
I am having problems viewing my contour lines after I create a surface. I create the surface using points.  The contour lines will show up when I create the surface. After I close the program or the drawing, I am not able to see the contour lines again. The contour lines are on in the surface style.  How can I see the contour lines without creating the surface again?
4 REPLIES 4
neilyj666
Do you have Level of detail switched on??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
in reply to: neilyj666
Where can I find the level of detail?
neilyj666
see screenshot - can you post the dwg if this doesn't solve the problem??
That worked. Thank you.
Rail Community
