rvandever21
Message 1 of 5 (737 Views)
Contour lines display
737 Views, 4 Replies
09-19-2012 12:38 PM
I am having problems viewing my contour lines after I create a surface. I create the surface using points.  The contour lines will show up when I create the surface. After I close the program or the drawing, I am not able to see the contour lines again. The contour lines are on in the surface style.  How can I see the contour lines without creating the surface again?
Do you have Level of detail switched on??
neilyj
Message 2 of 5 (732 Views)
Re: Contour lines display
09-19-2012 01:04 PM in reply to: rvandever21
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
rvandever21
Message 3 of 5 (722 Views)
09-19-2012 01:24 PM in reply to: neilyj
Where can I find the level of detail?
neilyj
Message 4 of 5 (713 Views)
09-19-2012 01:33 PM in reply to: rvandever21
see screenshot - can you post the dwg if this doesn't solve the problem??
neilyj
rvandever21
Message 5 of 5 (629 Views)
11-13-2012 01:23 PM in reply to: neilyj
That worked. Thank you.
