Civil 3D Forum
Contour Line Labels
12 REPLIES 12
Message 1 of 13
JeffCamarena
768 Views, 12 Replies
Contour Line Labels
I have my existing surface data referenced into my production drawing. I am trying to label the existing surface contour lines in the production drawing. I only have one surface in this drawing right now, so, I don't believe this is a multiple surface issue. When I try to add single and multiple contour labels to the existing surface, I cannot select a contour line. I try to click on a contour line, using osnap, and I just keep getting prompted to pick a contour line.
12 REPLIES 12
Message 2 of 13
tcorey
in reply to: JeffCamarena
Try closing and re-starting Civil 3D.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
JeffCamarena
Thanks. I did, to no avail.
Message 4 of 13
troma
Check the label style you are using.  Is it set to display?  Or is it hidden?  What layers is it using?
Generally a good test is turn all layers ON & THAWED.  Do a regen.  See if maybe there are some labels there.
Also check the annotation scale.  It's possible they're coming in so tiny you don't see them.
Mark Green
Working on Civil 3D in Canada
Message 5 of 13
tcorey
Detach referenced surface, save, close, re-start C3D, open drawing, reference surface again?
Tim Corey
Redding, CA
Message 6 of 13
JeffCamarena
I have tried all of that. Nothing seems to work. I can label the existing surface in the surface drawing, but I cannot label the data referenced surface contours in the production drawing.
Message 7 of 13
Jeff_M
Is the data referenced surface set to display the contours? Can you post the 2 drawings?
Message 8 of 13
tcorey
Can you reference a different surface and successfully label that?
Tim Corey
Redding, CA
Message 9 of 13
SkipBurns
I have typically found this to happen when a layer is frozen/off.  Don't forget that multiple layers control the display of Civil 3D objects (the object layer, the display layer in the style, and often layer 0)
Message 10 of 13
JeffCamarena
Every layer is on and thawed. I have attached a screenshot of the surface and the drawing with the surface referenced in. I tried data referencing another surface (Surface B) from another job (Job B), and I could not label that surface (Surface B) in the production drawing (Job A) either. But, Surface B can and is data referenced into, and labeled, in Job B production drawings.
Message 11 of 13
does promoting the surface into the current drawing allow you to label the contours?
can you post a copy of the drawing in question with just the offending surface in it?
Message 12 of 13
jmayo-EE
Waht version are you using? Do you have all the appropriate updates installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
John Mayo
Message 13 of 13
JeffCamarena
Thanks everyone. I got it to work. I think the drawing was corrupt. I opened a new drawing and copied everything over, and now it works.
Rail Community
