Hi all,
This kind of thread seems to have been around a bit but nothing specific enough for my issue!
Its very simple, I have several surfaces, all of which I have added a contour surface style. However! When I label them, only 2 x of the 4 x surfaces will display labels (see pic below). I have tried every method of labelling, checked that every layer is on (including the style) and they will not appear.
If I run Contour Labels Multiple or interval I can pick over the contours, the command completes but no labels? The other surfaces are fine which is the frustrating part!
Thanks for your help & wisdom is advance,
Whilst going through the process of deleting nearly everything out of this model to attach the file, the contour labels have appeared? I am not entirely sure at what point they appeared as it didnt expect them! I can freely label them with no problem, even though most of my information is now deleted (I did a saveas first!)....
