Civil 3D Forum
Contour Labels
2 REPLIES 2
GregVigna
2386 Views, 2 Replies
Contour Labels
Having trouble with contour lable styles.  Cannot not find away to adjust the precision as to which contour labels are displayed.  The default style has them appearing with two decimal places (ex: 100.00).  Anyone know where to adjust this setting?
2 REPLIES 2
rkmcswain
in reply to: GregVigna
  1. Toolspace > Settings Tab >Surface > Label Styles > Contour
  2. Select the style you want to edit, right click on it and choose Edit.
  3. Go to the Layout Tab, under Text, select the Contents value, (then click on the tiny button that appears in that field)
  4. In this editor, double click on the preview to select it, change the precision on the left, then click the "Arrow" button to update the preview
  5. Ok your way out of all of the dialogs.
R.K. McSwain     | CADpanacea | on twitter
GregVigna
Thank you sir, that did the trick!
Rail Community
