Distinguished Contributor
1 Kudo
Post 1 of 7
Contour labels visibility
408 Views, 6 Replies
01-07-2013 03:05 PM
Hi:
I am trying to make my contour labels visible, indepently of the Visible status of the contours in the surface style of the original surface that I am working on. I have to do this due the final topo looks strange in the borders so I am displaying another contours -that do not have elevation- and make look the drawing better. The problem is that if I turn off the Visible property of the contours, the labels turn off even that they were created in a different layer and attached to a label style with its own layer property.
Just in case you need more details, do not hesitate to give me a shout.
Thanks in advance
Rafael Moreno
Explode the labels.
267 Kudos
Post 2 of 7
Re: Contour labels visibility
01-07-2013 03:12 PM in reply to: RafaelMoreno
Use a layer within the surface style for your contours and then you can simply turn that layer off and the contours labels will remain.
Brian Hailey
CAD-1.com
My Blog
1 Kudo
Post 3 of 7
01-07-2013 03:43 PM in reply to: BrianHailey
Hi Brian:
Thank you very much for the quick response. I tried this and it works, the problem is that I do have several objects and all of them attached different Surface Styles. These surface styles call the same layers to display the contours so if I turn off the layers, the contours of all objects are going to disappear. I know that you told me that I have to create antoher layer for this surface but in this case I have to create several for the other surfaces.
Is there another solution?
Rafael Moreno
Active Contributor
3 Kudos
Post 4 of 7
01-07-2013 04:24 PM in reply to: RafaelMoreno
Explode the labels.
1 Kudo
Post 5 of 7
01-07-2013 05:54 PM in reply to: RafaelMoreno
Hi Brian:
Thanks for your answer. I will keep this as a solution. I have a quick question...do I need antoherh thread?
Rafael
267 Kudos
Post 6 of 7
01-07-2013 07:38 PM in reply to: arcallupe
arcallupe wrote:
Explode the labels.
NOOOOOOOOOOOOOOOO
Don't explode the labels! If your surface changes, the labels won't update. Simply copy the surface style and change the layers the contours are using. Do this as many times as necessary.
NEVER EXPLODE ANYTHING IN CIVIL 3D EXCEPT AS A LAST RESORT! The only last resort I would use is, "I have to get this out today and I don't understand how the program works so I'll explode it for now but as soon as I get a chance I'll figure out a way to do this without exploding".
Brian Hailey
CAD-1.com
My Blog
267 Kudos
Post 7 of 7
01-08-2013 07:03 AM in reply to: BrianHailey
Sometimes I think we need a thumbs-down 'anti-kudo' button for some posts.
Credit where credit is due! Give kudos or accept as solution whenever you can.
