Civil 3D Forum
contour labels not working
20 REPLIES 20
Message 1 of 21
wbrustle
1995 Views, 20 Replies
I created a surface and the only available data I had was proposed contours and a boundary. When I try to label contours, it recognizes the surface when I select it, but will not label....I see no labels when I select a contour. My label style is correct and all layers relating to the style are thawed, because I tested it on the existing surface, and labels show up fine.
20 REPLIES 20
Message 21 of 21
cad_lady
in reply to: wbrustle
Wow this is an old post, but better late than never.  Hopefully, you figured it out or found a workaround!
I just came across this same issue in Civil 3D 2016.
Here's the solution that worked for me:
TOOLSPACE palette -> Settings tab -> Surface -> Commands -> AddContourLabeling -> check the Contour Labeling Defaults.
Rail Community
