Member
dkozanecki
Message 1 of 9 (2,647 Views)
Contour labels not showing up
2647 Views, 8 Replies
12-20-2012 09:25 AM
This is the first time in a few years Im working with ACAD again so please excuse this question if its mindnumbing easy.
Im working with 2013 Civil 3D. I have a site with polyline contours that have assigned elevations. I created my surface from the contours but when i try to label them with elevations, nothing. I label them by contour-mulitple with interval. All that is inserted are tic marks at the designated interval. What am i doing wrong? Any help would be greatly appreciated.
It sounds like you might be trying to label your original polylines. That won't work. Freeze them and set your surface style to display contours at the desired intervals. Your labels should show up where the contour label line crosses the actual surface contours.
troma
Message 2 of 9 (2,643 Views)
Re: Contour labels not showing up
12-20-2012 09:36 AM in reply to: dkozanecki
Check your contour label style: is it set to display?  What layer is it set to?
Turn all layers on and thawed, see what happens.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Member
dkozanecki
Message 3 of 9 (2,639 Views)
12-20-2012 09:46 AM in reply to: troma
It shows that it is set to true so I assume means yes. I have to current layer set to TEXT. When I try to label a slope, the percentage of slope shows up. I don’t know if that matters. And yes, all layers are on and thawed.
*Pro
dgordon
Message 4 of 9 (2,625 Views)
12-20-2012 11:00 AM in reply to: dkozanecki
can you post the file for someone to look at?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
mconway
Message 5 of 9 (2,613 Views)
12-20-2012 01:00 PM in reply to: dkozanecki
There are several places that turn off the annotations. Check your styles first and be sure that A. You're adjusting the assigned style and B. That the visibility is set to True in both the "General" and "Layout" Tabs
Next, I'd select the annotation object itself and look at the "Properties." Be sure that the Display Major and Minor Contour Labels are set to True.
Finally, Be sure that the Annotative scale of your object is available in the current selected scale to check this click on the "Lightning Scale" Icon in the lower right corner of the Status bar.
At your service,
Mark A. Conway
Director - Applied Technology
Autodesk Certified Instructor
AutoCAD & Civil 3D 2014 Certified Professional
Infrastructure Design Suite BIM Specialist
Follow me on Twitter @CADventurer
Valued Mentor
KirkNoonan
Message 6 of 9 (2,604 Views)
12-20-2012 01:17 PM in reply to: dkozanecki
Valued Contributor
C3D_TomR
Message 7 of 9 (2,598 Views)
12-20-2012 01:23 PM in reply to: dkozanecki
Check the text height in the major and minor contour label style as well. Make sure it's set to 0.1 for 100 Leroy text size then verify that your annotation scale is set to the scale you will be plotting.
Member
dkozanecki
Message 8 of 9 (2,577 Views)
12-21-2012 04:16 AM in reply to: KirkNoonan
Kirknoonan, you are correct. I was trying to label the original polylines. Ive done more investigation and think i figured it out. I did get the labels to show up when i turned the surface contours on. Now i just need to do some tweaking.
Thanks everyone for the help!!
Member
dkozanecki
Message 9 of 9 (2,507 Views)
01-15-2013 06:07 PM in reply to: troma
It shows that it is set to true so I assume means yes. I have to current layer set to TEXT. When I try to label a slope, the percentage of slope shows up. I don't know if that matters. And yes, all layers are on and thawed. Thank you, Donnie Kozanecki Donnie Kozanecki, RLA Project Manager LEED Green Associate ISA Certified Arborist Prince William County Department of Parks and Recreation 14420 Bristow Road Manassas, Va 20112 703-792-7060 Prince William County Department of Parks and Recreation
