When I label my Contour lines there is a blue line(perp) running right thru the middle of it.
I have looked to take it off but can not find it. Thanks for help
Solved by Jay_B. Go to Solution.
"Contour Label Line" set to False in Properties Palette.
This Can also be set to False in the Feature Settings Tab> Surface>Rt. Click>Edit Feature Settings>Contour Labeling Defaults>Display Contour Line>False in the dwt.
If you have a bunch of them, select one, right-click and choose Select Similar so you can globally edit them.
Look into setting this behavior as default behavior in your company template so every time you place a contour label the lines automatically hide. Look at the attachments to see how to do this.
John Mayo
