Civil 3D Forum
Contour labels are not visible when XREF'd
26 REPLIES 26
Message 1 of 27
rkmin
5285 Views, 26 Replies
I have a topo drawing containing contours which are labeled with elevation.
I Xref'd this drawing into another drawing and the contour labels do not show up, so i have to re-create the contour labels.
Is there a way for the labels to show up automatically when XREF'd?
26 REPLIES 26
Message 2 of 27
troma
in reply to: rkmin
They should.
Have you checked all layers on and thawed?
Mark Green
Working on Civil 3D in Canada
Message 3 of 27
rkmin
in reply to: troma
All layers are thawed.
I have a drawing called "topo.dwg" that contains topo features and a surface (data shortcut).
I labeled the contours in "topo.dwg" and it shows up.
I Xref (overlay) "topo.dwg" into another drawing called "civil.dwg". Everything in "topo.dwg" shows up except for the contour labels.
Message 4 of 27
witzel
in reply to: rkmin
You may have an issue with units.  The contour labels may be there, just very, very small.  If that is the case in Toolspace | Settings right click the drawing and got to Drawing Settings.  Make sure that both drawings are set to feet (or meters).
Hope that helps,
Conan Witzel
Message 5 of 27
rkmin
in reply to: rkmin
They are both the same units.
Both drawings was created using the same drawing template.
Message 6 of 27
witzel
in reply to: rkmin
The only other thing I can think of is the layer the contour label object resides on.  That can be different than where the surface resides.
You said that in Topo.dwg, the surface is a Data Reference.  Antoher issue I have seen is labeling xrefs.  If I remember correctly, labels on xrefs don't travel.  ie. if topo.dwg contained an xref to a surface and you labeled it there, if you then xrefed topo.dwg, the labels would not show up.  A little like overrlay vs attach.
Conan Witzel
Message 7 of 27
rkmin
in reply to: witzel
So, am I correct to understand that contour labels are not contained as a part of a Data Shortcut?
Message 8 of 27
witzel
in reply to: rkmin
No, they are not part of the surface.  The are used to annotate the surface in a drawing.  Our workflow looks like this:
We create the proposed surface in grading drawing.  We create a reference to the surface.
We reference the surface into a grading and drainage drawing.  This is where the annotation occurs.
We XREF the grading and drainage drawing into the plot sheet drawings that need it.  We will never see any labeling in the drawing where the surface is created and edited, but we can see the annotations that are placed in the grading and drainage drawing.
Does this make more sense?
Conan Witzel
Message 9 of 27
rkmin
in reply to: witzel
I think I understand your example. For my situation, I just wanted to eliminate having to recreate contour labels for any subsequent drawings that are Xrefing the original drawing containing the surface.
Now, I'm having a problem where I labeled the contours from "topo.dwg" which is then Xref'd into "civil.dwg". Now, in "civil.dwg" I get a message at 0,0 saying that Label Contains a Broken Reference ever since I created the contour label. What did I do wrong?
Message 10 of 27
witzel
in reply to: rkmin
It may be an issue with the project folder.  I would AUDIT both drawings.
In the topo.dwg drawing in the tools space make sure that the surface is referenced correctly.Capture.PNG
in other words no yellow warnings.
Just to be clear, you should only have to label the surface once.  XREFing the drawing should show the annotation.  Data referencing the surface will NOT bring the annotation.
It may be that you have an issue with the original surface and once that is fixed you will get the result you want.
Message 11 of 27
rkmin
in reply to: witzel
I ran an audit on all my drawings that are referencing that data shortcut folder and there were no errors.  I also do not see any yellow error warnings in the prospector. I'm not sure why all of a sudden this popped up after I simply labeled a contour.  If it isn't one problem, there comes another.
Message 12 of 27
Jeff_M
in reply to: rkmin
Is the Xref inserted at 0,0 with 0d rotation?
Message 13 of 27
Jay_B
in reply to: rkmin
Is the text height set to zero in the "text style" used in the "text component editor" format tab of the contour label style in use (source file) that wont display when xrefd to other file?
Verify the "text style" default height is set to zero in each file on the text style dialog.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 14 of 27
bnesja
in reply to: rkmin
I see this post is older and has not been answered yet. I too am having this issue but have noticed that the labels end up on the same layer as the surface when referenced. I assume you are doing what I am and turning off the layer for the refenced surface so you can modify the display of the Shortcutted surface. When you turn off that surface layer the lables are going with it. This won't be noticed untill a Regen/ RegenAll.
Message 15 of 27
juanmagmen
in reply to: bnesja
If you can see it on model space and not on the viewport, try detached the xref, and attached again. it should show the text, also try Annotation Visibility turn it On on the icons or ANNOALLVISIBLE to 1
Message 16 of 27
Joe-Bouza
in reply to: rkmin
I see this is an old one. I just experience it today. There was an issue way back with LDT files, and sure enough I ran into one todY. Not so much a LDT project but the user copied an old job to make this one And my theory is the junk came along for the ride. Correlation: I xref into a clean dwt created file and the labels . show coinsidenc? Doubt it. I hate when user drag old crap into a file
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 17 of 27
annw2
in reply to: rkmin
We have a similar problem with surfaces in 2014.
The surfaces are shortcutted into the layout drawing.  If we don't manually synchranize the surfaces, they often don't show up.
Ann Wingert, P.E.
Message 18 of 27
rkmin
in reply to: annw2
I have never found a solution to this problem. The workaround for me is that I don't use Civil 3D anymore. I went back to using Land Desktop 2009 companion since that software is much more Surveyor friendly. Not the answer to this problem but I had no other choice for me. I'm hanging onto Land Desktop until something forces me away from it.
Message 19 of 27
jmayo-EE
in reply to: rkmin
Wow. Going back to LDD would be absolute torture for me. Everything I did would be slower from field topo, to design to stakeout.
John Mayo
Message 20 of 27
Joe-Bouza
in reply to: jmayo-EE
Going to LDT that's a bit harsh. I'll bet a cup of coffee if they are refed into a clean c3d.dwt file they show load and proud.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
