There is a setting in the PC3 file that will fix this. It is called Merge
Control. It must be set to Line Overwrite for the masking to work. This will
also allow mtext background masking to work. The disadvantage is if you use
shaded linework, they will plot on top of solid linework unless your draw
order is set properly. This is also true of solid hatching. If you have a
Xerox plotter, then you can't use the HDI driver, you have to use the HPGL
system printer driver to get them to plot. Then if you want to print raster
images with that system printer, good luck. I have been waiting for Xerox to
come out with a new driver for about two months since I discovered these
problems.
If you are printing directly through a system printer, you will have to
change your ways and setup a PC3 file, but you can still have the PC3 file
print directly to your plotter.
Tom Berning
Woolpert, Inc
Dell Latitude D800, 1.6ghz 2gb RAM
Win 2000 SP4
Civil 3D 2007, LDT 2007, LDT 2005
wrote in message news:5271838@discussion.autodesk.com...
It seems none of the label masks I've done are working either. My
textmask/wipeouts work on my HP plotters, and they exist side-by-side with
C3D's label masks. Obviously it's a different process for masking.
