Randell,
The procedure you are going through is the recommended way of removing the
Contour Label Line.
On a side note: you can set the styles for the Contour styles by setting up
the styles in the command settings. Go to the settings, surface, and edit
the CreateSurfCntrLabelLine and set the styles for the Major and Minor
contour styles.
Dan Philbrick
Autodesk, Inc.
"D Randell" wrote in message
news:41b9de88$1_1@newsprd01...
> Hi, I just finished labelling some contours and all of the contour label
> lines are still there. I have managed to remove them by changing them to a
> layer that I can freeze. Is there another way of removing them without
> affecting the text? Thanks.
