Civil 3D Forum
Contour Label Lines
1 REPLY 1
118 Views, 1 Reply
Contour Label Lines
Hi, I just finished labelling some contours and all of the contour label lines are still there. I have managed to remove them by changing them to a layer that I can freeze. Is there another way of removing them without affecting the text? Thanks.
1 REPLY 1
Randell, The procedure you are going through is the recommended way of removing the Contour Label Line. On a side note: you can set the styles for the Contour styles by setting up the styles in the command settings. Go to the settings, surface, and edit the CreateSurfCntrLabelLine and set the styles for the Major and Minor contour styles. Dan Philbrick Autodesk, Inc. "D Randell" wrote in message news:41b9de88$1_1@newsprd01... > Hi, I just finished labelling some contours and all of the contour label > lines are still there. I have managed to remove them by changing them to a > layer that I can freeze. Is there another way of removing them without > affecting the text? Thanks. > >
Rail Community
