Valued Contributor
jamesbarnett
Message 1 of 8 (278 Views)
Contour Label Directions
278 Views, 7 Replies
12-04-2013 12:14 PM
Is there a way to change the direction of a Label? I want all my text facing the same direction and some of my Labels for contours are turned the wrong direction.
AutoCAD Civil 3D 2014 SP 1
Windows 7 (64)
You can try turning Plan Readable to False in the Label Style.
HTH
AWood
Valued Contributor
g_k50
Message 2 of 8 (274 Views)
Re: Contour Label Directions
12-04-2013 12:28 PM in reply to: jamesbarnett
Click on the contour label and move it over a little bit, it might flip upright.
Valued Contributor
jamesbarnett
Message 3 of 8 (271 Views)
12-04-2013 12:35 PM in reply to: g_k50
I tried that. I have to move it to far.
Windows 7 (64)
mikehathaway2942
Message 4 of 8 (268 Views)
12-04-2013 12:39 PM in reply to: jamesbarnett
I have never had to do this but if you go into the contour label style editor you can manipulate the settings to achieve the desired results. It may take some trial and error.
Valued Mentor
awood
Message 5 of 8 (264 Views)
12-04-2013 12:50 PM in reply to: jamesbarnett
HTH
AWood
Valued Contributor
g_k50
Message 6 of 8 (258 Views)
12-04-2013 12:52 PM in reply to: jamesbarnett
You could rotate your cube until the label flips.
TRogers
Message 7 of 8 (245 Views)
12-04-2013 01:26 PM in reply to: jamesbarnett
In your text style under the General tab, change the Readability Bias to 90.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
jamesbarnett
Message 8 of 8 (224 Views)
12-04-2013 03:29 PM in reply to: awood
Turning the Plan Readability off fixed my issue.
Thanks everyone.
Windows 7 (64)
