I am trying to add some parts to enhace the availability of valves, hydrants, etc to the pressure pipes catalogs. I have a 3D solid of a 6" flanged DI gate valve that has an ACP inserted into the drawing file per the Autodesk Part Publishing Wisard User Guide. Following those directions, I have used the publishpartcontent comand and created a .content file for this valve. I then open the Content Catalog Editor to add my new valve. I have tried creating a new catalog and also adding this part to an existing catalog. Each time it crashes at the same point. I click the Import Part button, select my conten file, and the following message pops up: "CataloEditor has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
My content editor is doing the same thing. Did you get this figured out?
Thanks, I found that shortly after posting. Forgot to update the thread.
