Civil 3D Forum
Construction Notes
32 REPLIES 32
Message 1 of 33
kadeking
4376 Views, 32 Replies
Construction Notes
I am looking for a way to create a master list of construction notes then use blocks attributes with fields to link to that master list. That way if the master list changed the note bubbles would change as well.
Sheet sets are being used with this project but I can't think of a way to make it work with the existing sheet set technology.
I would appreciate any ideas that anyone has to offer.
32 REPLIES 32
Message 2 of 33
Lisa_Pohlmeyer
in reply to: kadeking
My thought would be to do this the other way around.  Create the master list of notes, each note of which is an attribute. Then where you want to show that note attribute value, create a text object with a field that links to the blocks attribute value.  See attached drawing. (Rel 12)
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 3 of 33
kadeking
in reply to: Lisa_Pohlmeyer
Lisa,
Thanks. I should have posted that we had already looked at that option but it's pretty time consuming to create the object field links every time you add a new one, plus it would only work on the current file, with no way to work within an entire project. I'm thinking that outside of programming code, this is basically a new feature reqest.
I submitted a feature request to Autodesk that they add a tab to the Sheet Set Manager for Construction Notes or Key Notes or whatever they want to call it. You construct a list of notes, then you can right click on them from that tab to add a reference to the note on the drawing. Then if you update the list the references update.
I'd love to see this feature added to basic AutoCAD, which would of course push it up through the verticals.
Thanks for your response!
KaDe
Message 4 of 33
troma
Couldn't you add some custom properties to the sheet set?
Mark Green
Working on Civil 3D in Canada
Message 5 of 33
Lisa_Pohlmeyer
in reply to: troma
Sure they could add custom fields that would work across the entire project, but again, that takes some up front work and I think they're wanting something that makes it a little easier to add to each sheet. I use custom fields for our sheet sets and they're included in our template, so makes it a little easier.
Lisa Pohlmeyer
Civil 3D User
Message 6 of 33
troma
Yes, it's quite a bit of work on the sheet set and the notes.  But once you do the notes, you can copy paste them to all drawings.  And it achieves the stated goal: if you change a note, you can change it in one place and all drawings will update.
Mark Green
Message 7 of 33
Lisa_Pohlmeyer
in reply to: troma
That's a great thought... I was taking the approach to individual notes.
Lisa Pohlmeyer
Civil 3D User
Message 8 of 33
tcorey
The way I have handled this is to create a master file of Notes, and then make a View of each note.
Now I can just drag-n-drop each note onto any sheet. They are automatically xref'd, so if/when changes happen, they are updated to the sheets.
This has the added benefit of allowing me to place, on other sheets, Callouts that point to these notes. If a note's page number or view number changes, the callouts will change throughout the sheet set.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 9 of 33
Neilw_05
Map can link drawing objects to spreadsheets and database tables. I've contemplating using it just as you are wanting to do but I've never gotten around to putting it together.
What you could do is create your callout blocks with an attribute that corresponds to the database table. Then generate links between the block attributes and the database table. From there you can display the fields from the database table in your drawings. I'm not current on Map's linked tables capabilities since 2004 so I don't know if you can make a linked table that is displayed in a drawing dynamicly update when the database table or the block attribute changes. If I can get some time I'll go through it. In the meanwhile someone might be able to offer more insight on that approach.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 10 of 33
kadeking
Thanks to everyone for all the wonderful suggestions!
We'll be trying a few of these options to see what works best!
Best regards,
KaDe King
Message 11 of 33
mgarrett
There is the option out there for third party software. We work with one called "Construction Notes Manager" which when installed allows me to create a word file with all the keynotes in it and then in AutoCAD there is a custom toolbar with shapes that correspond to the word file when the correct number is entered. The software then runs a simple macro to compare the cad file with the word file and publishes the keynotes in the same drawing. When you update the word file, you reinsert the block into Cad and the notes update. It may be the direction you are wanting to go.....
Message 12 of 33
kbiggs
in reply to: mgarrett
Thanks for the recommendation of the "Construction Notes Manager", it looks promising. Currently we have a set of master Word doc's that we open and copy/paste any note to a multi-leader. Somewhat tedious, however, it does help standardize all our notes, which can be edited outside of AutoCAD.
Keith Biggs
Chair, CAD Standards Committee & Senior CAD Technician
R.F. Binnie & Associates Ltd.
Leading in Quality: OQM certified March 2013.
Message 13 of 33
Joe-Bouza
in reply to: troma
Thats where my vote goes
Joe Bouza
Message 14 of 33
Joe-Bouza
in reply to: tcorey
As a view callout? doesn't that bring in an occurance of the xref for every callout block dragged in? model space can get pretty messy and a lot of vports.....
But I like the idea.
Joe Bouza
Message 15 of 33
Joe-Bouza
Lots of great ideas.
I'm a SSM hound and like that approach but if the master list gets lenghty it could be difficult to navigate.
here another opton: Excel link to a table then you could link a table cell to any note, block attribute etc. the table has the added benifit of overriding a note cell for a given sheet, or amending without effecting the entire set if need be. Or for that matter, amend and write back to excel for the whole set to see the effect.
Joe Bouza
Message 16 of 33
tcorey
in reply to: Joe-Bouza
@Joe-Bouza wrote:
....doesn't that bring in an occurance of the xref for every callout block dragged in? .....
No, if the model views are in the same drawing, that drawing only get xref'd one time.
Tim
Tim Corey
Redding, CA
Message 17 of 33
Jeff_M
in reply to: kbiggs
I case anyone comes across this thread, I've added this to the IdeaStation so we can have this capability built-in to C3D.
The more kudos it gets, the better chance of it happening.
http://forums.autodesk.com/t5/autocad-civil-3d-ideastation/adding-construction-notes-bubble-notes/id...
Message 18 of 33
jbernal
in reply to: Jeff_M
I have been asked this same Construction Notes update question a few times and have not been able to come up with a solution. Have there been improvements in the software since this thread has been started (in 2012) that will help in dynamically updating notes?
Message 19 of 33
Jeff_M
in reply to: jbernal
@jbernal, unfortunately the answer is no.
Message 20 of 33
TerryDotson
If you were to consider third party add-ons, DotSoft's ToolPac contains a KeyNote system that automates the process by letting you edit your master list, select an item and quickly place a block with attribute (or mtext, leader), then scan the drawing for those key annotations and build a table object of the keys with their descriptions.
tpAnnKeyNot
Rail Community
