Somehow constraints have been turned on and I can't get rid of them - any ideas??
neilyj (No connection with Autodesk other than using the products in the real world)
Set the CONSTRAINTINFER variable to 0.
(Command is same)
Thanks i tried that and still weirdness is occurring.....I've now WBLOCKed the filke as a new dwg and it seems ok
DelConstraint will delete them if that's what you need.
Thanks Matt - I don't want or need the constraints so I'll try this approach
