Valued Contributor
BtimmermanMMS
Message 1 of 3 (392 Views)
Consecutive vertical curves - Civil 3D 2013
392 Views, 2 Replies
02-14-2013 03:37 PM
Can Civil 3D 2013 create consecutive vertical curves (FG) for the profile. I've had to resort to putting the 2nd vertical curve in with a .01 difference in length to have it be created. I have read some of the previous posts to this issue, but have NOT found a viable solution yet.
 I would think with all the abilities of the software that this should be something that can be accomplished.
Any help greatly appreciated.
sboon
Message 2 of 3 (359 Views)
Re: Consecutive vertical curves - Civil 3D 2013
02-14-2013 10:20 PM in reply to: BtimmermanMMS
If you're trying to create back-to-back vertical curves by drawing a series of tangents and then adding two free curves then there's no tangent left between them for the curves to attach to and it's not going to work.  My solution was to use two fixed tangents, add one floating curve on the left side, and then add a free curve to finish it off.
New Member
efrailing
Message 3 of 3 (198 Views)
12-05-2013 09:24 AM in reply to: BtimmermanMMS
I found that if you create a curve slightly shorter than what you want (VPI where you want it, but have a curve length ~5-ft shorter), you can then use the grip editor to drag the curve to the proper length/have the next curve start exactly where the previous curve ended. Magically, your table editor will update correctly, even though it won't let you type those values in directly.
Windows 7 Enterprise SP1 64-Bit
Intel Xeon @3.20 GHz
12 GB RAM
