We have a problem where we have a straight pi that runs into a curve pipe. These pipes are not joined with a manhole. We want to show these pipes as on now we can lable only one and edit the labe but it would be better if we could join them using a command like pedit join.
Does anyone know how to do this.
Solved by Jeff_M. Go to Solution.
Hi Jon-
You can merge the networks: http://beingcivil.typepad.com/my_weblog/2010/04/2011-preview-pipe-enhancements-splitmerge-pipe-netwo...
Hope this helps!
That is good news to hear but our problem is with pipes in the same network.
What we have is from MH-1 to MH-2 a 4m straigh run then a 12m curve then a 80m straight run. what i am looking for is the ability to make this into one pipe from Mh-1 to MH-2
