Dear all,
I need some help with the following issue:
I would like to have the corridor (1) connected to (2).
(2) is my Exisiting Surface -0.05m.
This is a screenshot of a part from the overview. I can make an alignment there, but how do I connect the corridor(the bottom) with that alignment?
Hope somebody can help me,
Thanking you in advance,
Lex
The corridor is working fine, but after adding the 'basic lane sub assembly' it's random adding the 'Basic Lane' somewhere.
Edit: i misclicked ' Solution ' by your post.
I will try to explain the situation in one post:
This is my corridor/assembly in section view.
On the right you see a corridor (marked point)
This is my assembly:
Corridor in object viewer:
What I want:
- Connect a lane from my existing assembly with a thickness of 0.10m to the marked point.
Why I want that:
- My current assembly is matching my EG surface (top cyan) on 7.5m from the centerline now on either the right or the left side. (this is good)
Lex
Joe Bouza
Joe Bouza
Joe Bouza
I think the idea is good, the problem is still the the 'start' of the sub-assembly is randomly..
edit: Maybe im doing something wrong here:
it appears to me you put the assembly on the left side of the OMII and are targeting the right side of the road? and you will want a verticle trarget too; EG along the offset alignment
Joe Bouza
That is not what your section shows.
Lets clarify: the right side is percieved looking up station, yes?
Your section clearly shows the sub starting on the left side?
Joe Bouza
Funny thing is, if I attach it to the left side, it works fine.
(this is attached to both side in section view)
I found the problem i will post it in a sec.
This type of sub-assembly OverlayMillAndLevel2 doesn't use a profile to form it's shape in the corridor/section view. By changing the parameters in this sub-assembly, the corridor will change(not matching the assembly). When I add anything to the outer side of the subassembly, it will not follow this outer part in my corridor/section view:
Example:
Correct the MOII does not support profile of the outter edge. what is it exactly is the peice you are adding? And what parameters in the OMII are you changing?
Joe Bouza
I've added the SuperElevationLane subassembly. I want it to match to my alignment. (which is not in my model yet)
The parameter I'm changing is the minimum clearance..
Maybe there is a different way to accomplish my needs:
0.00 to 7.50m I want to target the EG surface under 1,5% (right now it is good)
7.50m to 15.30m I want to target the EG surface. (this is what is not working)
Maybe I can get my levels from the centerline from this corridor surface and use them to make a profile. Then make an assembly to (lane) with 1,5% (width 7,5m) and 1% (width 7.8m, this slope has to change automaticly since the 15.30m EG level is differently in the sections) to 15.30m.
Is there an easier way? I'm a little lost.
It follows EG at the crown point
Joe Bouza
Example:
I'm not convinced this is wrong. I think you have a piculiar code set style setting that may be confusing us.
Is not the red line your corridor surface? Earlier you stated you were holding 1.5% min and the top of the grey shape is way steepr that that. And what are the yellow lines? If I had to guess ( and I do have to guess) the red line is the top of your corridor, the triangualr area made by the two yellow lines are the milling and the area between the red and yellow is the overlay. Therfore, the outsidesure sub is correctly connected to the top of the overlay.
One thing you can do with the super peice is get the cross slope to match the overlay slope: in the construction tab of the assemble properties you can pick the cross slope pop down to get the cross slope from the overlay sub. I'm not in from of c3d right now and im not 100% sure of the pop down but its in there
Joe Bouza
Thanks for your answers. I'm still testing it.
One more thing, any idea why my top corridor looks like this?
Left side is working good now. Right side is still strange. Can't find why it's attaching like this.
What could cause this?
Joe Bouza
