Civil 3D Forum
CONNECTED PIPE EXPRESSION?
6 REPLIES 6
alexkonieczka
1170 Views, 6 Replies
I have a surevy with piping & structures done at an assumed elevation i would like to keep as is.  picking a bench elevation and subtracting the difference i was able to make expressions (like grate & sump - 100.07) that i put in my label that showed both elevations:  eg.  grate = 105.3 [5.23] where the real elevation is ~5.23 which can be compared to the original design intent.
This worked well except when I made and expression for the connected pipes (pipe in/out) in the structure labels section they do not show up as an option to be places in the label.  Is there a way to do this?
Thanks Alex
6 REPLIES 6
tcorey
in reply to: alexkonieczka
This topic came up about six months ago and no one was able to provide a solution. Wish list...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
alexkonieczka
in reply to: tcorey
thanks.
Try creating a custom parameter for the structure:
http://blog.civil3dreminders.com/2009/04/pipe-network-custom-parameters.html
It works for both pipes and structures.
Then put the value in the field. You'll probably not want to manually put the value in, so you might want to try a third party product to assist. I know the Steltman tools will do this in Excel and then import the change back into Civil 3D into the pipes.
You are able to make a structure label that looks like this?:
grate = 105.00 [5.00] this works for me. assume we are taking 100 off
all info.
sump = 100.00 [0.00] this works for me using an expression.
pipe (n) = 102.0 [2.00] this does not work
pipe (s) = 101.0 [1.00] this does not work
Yes, the custom properties contained within the link should accomplish that. You'll need to enter the value in the pipe properties, you can't use an expression, but it will populate the value within the pipe label.
Here is how to do truncated elevations.  (i.e. 1100.325m -> 100.325m)
You have to separate the values into left of the decimal, the decimal character and right of the decimal.
For the left of the decimal yo have to use units a bigger unit. (i.e. Kilometers, miles)
<[Connected Pipe Invert Elevation(Ukm|P3|RN|AP|GC|UN|Sn|ORD)]>
The add just the decimal character.
<[Connected Pipe Invert Elevation(Um|P3|RN|AP|GC|UN|Sn|ODS)]>
for the right of the decimal you can use your normal units. (i.e. meters, feet)
<[Connected Pipe Invert Elevation(Um|P3|RN|AP|GC|UN|Sn|ORD)]>
So you would end up with the following in your label style.
<[Connected Pipe Invert Elevation(Ukm|P3|RN|AP|GC|UN|Sn|ORD)]><[Connected Pipe Invert Elevation(Um|P3|RN|AP|GC|UN|Sn|ODS)]><[Connected Pipe Invert Elevation(Um|P3|RN|AP|GC|UN|Sn|ORD)]>
Regards
Dave
Rail Community
