Hi. I have 4 corridors on same alightments (pics1). I created materials for each corridors (pic2). Then I created multiple section view for each corridor (pic3) ( for all corridors in section view table tab, i added corridors own materials). but cumulative material volume reset to zero at each new corridors begining. In my project, corridors cumulative material volume value should continue from the previous corridor's value. Can i connect this volume tables or can i merge corridors ? Thanks
Solved by sboon. Go to Solution.
there are 4 intersections in project. i made them at first then stretched end. after all, i got 5 corridors and 1 alightments.
Can i merge corridors? Can i connect materials volume table or i have to make 1 corridor ?
You cannot combine the materials from separate sample line groups, but if they're all sampled along the same alignment then you should be able to create a material list that includes data from multiple corridors.
Assuming that you've created a surface for each corridor then you'll need to create two materials for each. For the first corridor you would have a Cut1 and a Fill1 material comparing EG to the corridor surface. The second corridor would have its own pair of materials etc. When you produce the volume tables or reports all of the Cut materials will be combined as will the Fill materials.
thanks sboon but i already did them and i have no problem with "total tables".. i have problem with section view tables (next to section view) (pic4). you can see how i created them at pic2 . in this table, cumulative material volume reset to zero at each corridors beginning
I can't tell from your pictures how your structure type materials are defined. In mine I have one Pavement material set up to include both the Pave1 and Pave2 sections from both of the corridors along my alignment. I did the same for the Base and SubBase quantities. My section view quantity tables are working correctly and don't reset to zero at the start of the second corridor.
i added all corridors materials separately. thats my wrong 🙂 . thank you very much for your help. it's exactly what I was looking for.
