Distinguished Contributor
bruce.jordan
Message 11 of 15 (188 Views)
Re: Connect to Raster Data
09-29-2010 12:02 PM in reply to: wdbar
Try this -
In your options make a note of your Temporary External Reference File Location" under the Files tab and get Full Control permissions to this folder.
There are some files that get created and attributes set when attaching raster images.
-Bruce
machadt
Message 12 of 15 (94 Views)
02-19-2013 12:17 PM in reply to: bruce.jordan
This issue is caused by lack of permissions. If you go into
Options menu>Files tab and locate “Temporary External Reference File Location”.
This revealed the path where program copies it. Users must be given full rights to this location
(C:\Users\<username>\appdata\local\temp\).
As an alternative some people recommend creating another temp location such as C:\TEMP and setting “Temporary External Reference File Location” to there while ensuring user has full permissions. More about permissions could be found here.
Tatiana Machado
AEC-ENI Application Engineer
Valued Contributor
shunter62
Message 13 of 15 (87 Views)
02-19-2013 01:15 PM in reply to: rg7603
This problem was just solved for me this morning in 2012. Make sure that you have permission to access the folder where your temporary files are stored. For example, I had mine set to a network drive and did not have full control over that drive & folder. I made a folder on the C: drive called _{my initials}_Temp and used the Options settings to direct files there.
Immediately my FDO worked correctly for both rasters and shapefiles.
My deepest thanks to Tatiana Machado of the Autodesk Subscription Help Team for solving this.
Please see if this helps.
Susan H
Valued Contributor
shunter62
Message 14 of 15 (83 Views)
02-19-2013 01:17 PM in reply to: machadt
Ha Tatiana, you beat me!
Susan
machadt
Message 15 of 15 (81 Views)
02-19-2013 01:18 PM in reply to: shunter62
LOL... It is my pleasure to help!!!
Tatiana Machado
