I have been searching for the answer to this for a long time now. I have a simple graded pad on a hillside. I want to design a driveway that connects the pad to a road down the hill. I'll create a corridor to control the driveway but now I can't seem to merge the two surfaces together to form a continuous surface for earthwork calculations. Unless I start the driveway at a daylight point, I have yet to find a solution.
I've tried creating a new surface and pasting in both other surfaces but the problem is that where they intersect there is a dip --and depending on the order of the surface pasting, determines where the gap falls but I still can't seem to get them to just merge cleanly. Can anyone help me perform this seemingly simple and common operation??
Solved by mathewkol. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
For this I would make driveway and pad all one Corridor for a smooth transition on to the pad. No grading objects to worry about.
Need some driveway radii in there so trucks don't catch a tire and roll.
