When using Profiles from Corridor Feature Lines the Intersection Wizard produces the following message at the end of the process, and cannot lock the Secondary Profile to match the Primary Road Profile.
Fred
that's not exactly a confirmation,
I logged that once and it was eplained to me that the primary and secondary alignments should only have 1 layout profile associated with them, or something like that
Joe Bouza
Joe,
This is definitely a Confirmed Defect that was produced and replicated by Autodesk this week.
The situation your talking about is when a surface profile (typically an inadvertently chosen EG profile) is used for a Primary and/or Secondary profile instead of a Layout profile. Then the Wizard will not lock those profiles because they could be subject to change when surface data is added or changed. This message will pop up as a warning to the User, and is valid in that case.
It also hapenning to me. I´m using rehab assembly in my intersection. I don't know how to fix this. Does anyone have any idea that may help me progress?
Thank you anyway.
Still an issue in 2017. The primary road profile shifted and the "dynamically linked" secondary road profile did not adjust to match it. I unlocked and attempted to re-lock the PVIs and received this message. The only fix I can find is recreating the intersection, which is a pain when I've already made the corridor.
Still a problem in 2018. Might be worse, as I have to recreate my secondary profile after. It is getting flattened to zero elevation.
