Civil 3D Forum
Compute Mixed Materials
13 REPLIES 13
Message 1 of 14
Umit.Arslan
551 Views, 13 Replies
Hi everyone,
      - What i want to do is to compute the material (excavation) from 3 intersecting surfaces using the "add a subcriteria" method.The area i want to compute is seen on the attched picture.
      - Also i want to learn if its possible to add extra grip points to a static section line on the section view.?
Any help would be appreciated..
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
Windows 8.1 Pro 64-bit
32GB RAM
13 REPLIES 13
Message 2 of 14
wfberry
in reply to: Umit.Arslan
OK, so apparently, you are not paying for material over-excavated and not paying for material that was not excavated to the proposed typical section.  Hopefully someone can relay a simple answer but I do not know one.
I would plot all the sections out (in the dwg) and draw a polyline around each area and calculate it somewhat manually.
Bill
Message 3 of 14
fcernst
Right, use a Subcriteria.
Are you saying Civil 3D is not calculating the Cut below EG and above  the Survey and Design surfaces correctly?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 4 of 14
Umit.Arslan
in reply to: fcernst
Iam not saying that.I am just asking is there a way to calculate the area
shown on the attached picture using subcriteria. Thanks
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 5 of 14
fcernst
Yes, use the Subcriteria as I mentioned.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 6 of 14
Umit.Arslan
I have already tried many possibilities as subcriteria but didnt
success.thats why I am expecting some more detailed help.can you please
show the order and the number of subcriterias under compute material
window...
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 7 of 14
fcernst
Please show a screenshot of your Subcriteria for comment.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 8 of 14
Umit.Arslan
Ok.tomorrow I can put a screenshot. Thank you.
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 9 of 14
Umit.Arslan
Excuse me for the delay.The screen shot is attached.
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 10 of 14
fcernst
You don't want to have the Project Surface in the subcriteria to isolate that hatched area you want for volumes.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 14
Umit.Arslan
No.I use project surface when the site survey line is lower than project surface.In this condition the project line is used for calculation.
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 12 of 14
fcernst
Use two Cut materials. You don't need to implement Subcriteria.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 13 of 14
Umit.Arslan
Thanks for your attention.It would be perfect if you can send your dwg file to:  umitarslan78@gmail.com
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
32GB RAM
Message 14 of 14
RalphBrown99
Hi Umit:
I am doing a Volume calculations with Civil 3D with the same criteria that you have in this posting. However, doing the method of the last person in your section is not working for me. I am having a similar situation: The client is paying for the excavation above the design nothing below the design. How to do this volume? If you solved, please give me a shout.
Regards
Ralph
Rail Community
