Civil 3D Forum
Compute Materials Query
5 REPLIES 5
neilyj666
304 Views, 5 Replies
Trying to calculate volumes via compute materials and referring to screenshot: Am I correct in thinking that the soft clay volume can only be calculated correctly if the earthworks slope is extended to the base of soft clays?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
5 REPLIES 5
jmayo-EE
in reply to: neilyj666
I am thinking the shape needs to close to compute the area then vol.
John Mayo
sboon
in reply to: jmayo-EE
In this case your material section is going to have a vertical face on the left side, from the toe of earthworks slope down to the base of the soft clay.
Steve
Expert Elite Alumnus
jmayo-EE
in reply to: sboon
How would you attempt to get this number Steve? I know a second corridor can be run along the daylight and extend down to the base but is there a way with one corridor?
John Mayo
sboon
Daylight the earthworks to the top surface, then add a conditional test on both sides.  If the daylight point is above the bottom surface then add another daylight link to finish the section.  Note - you can also reverse the whole thing and daylight to the bottom surface instead.
Steve
neilyj666
in reply to: sboon
The vertical face I can live with but will the software "create" this itself and thus compute the "correct" volume as the Help seems to suggest?? I would normally do this via Analyse Volumes but the added complexity of several subsurfaces prompted me to try another method (the Analyse volumes would also just "cookie cut" at the edge i.e. assumes a vertical edge).
I'm trying to avoid having to add a new breakline to the earthworks surface based on the levels found at the soft clay horizon.
Rail Community
