Civil 3D Forum
Composite profile of a surface
6 REPLIES 6
1017 Views, 6 Replies
I'm using Civil 3D 2011 and working on a planset that requires showing a composite profile of a plan area surface (Basically, I need to show a profile of all the high points on a surface within an area represented along a single alignment).  Is there a way to make this profile short of making multiple profiles and manually connecting the high points to make a single composite profile?
Phil
6 REPLIES 6
Neilw_05
I would drop COGO points at the high points you want and build a surface from them. Then sample that surface to show it in your profiles.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Neilw_05
in reply to: Neilw_05
Well now I wonder if I misunderstood your task. It s a bit vague. Are you wanting to show all the high points within a set swath width along your alignment? Are you wanting to project all the highpoints of the entire surface onto your profiles? Are you wanting to show a profile of a surface consisting of only the high points (per my first approach)?
WIN 10 64 PRO
To show the high points, you could use the new Transpotation tools that is an addin. I believe one of those tools has the high pont that I believe you are asking about unless I am misunderstanding your question too.
BrianHailey
If anyone is interested in more info on the Transportation Extension, I wrote it up on my blog. You can read about it HERE.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
@ Neil:  Yes, I am wanting to show a profile of a surface sonsisting of only the high points in a certain area - I would like to use an approach that doesn't involve me manually picking the high points to use.
@ Rick:  Thanks for the info - the tool did help, although its still basically the same approach as Neil suggested.
@ Brian: Thanks for the info.
I was able to solve the problem by using the mill and overlay assemblies included in the pavement rehab assembly catalog.  I set a minumum clearance from the existing surface, set the grade to 0 and set the boundary targets to the polyline extents of my area.  The surface that this corridor then created profiled the highest points along the surface in the area I was looking at without me having to manually pick all the high points.
Hope this helps if anyone else runs into this problem.
Thanks for the help and the info!
-Phil
Any way you could walk me through that process?
Rail Community
