Member
0 Kudos
Post 1 of 7
Compatibility
275 Views, 6 Replies
04-20-2012 11:05 AM
Hello everybody,
need you help. To use autocad model in SAP2000 software or ANSYS I use .dxf file and choose autocad 2004/LT2004 or  2000 to import it to SAP2000 v14. But it don't work given that the .dxf file generated by Autocad2006 work perfectly.
please help in my computer I have only Autocad 2012.
I have Autocad civil 3D as 2012 software in Window 7 OS.
485 Kudos
Post 2 of 7
Re: Compatibility
04-20-2012 11:59 AM in reply to: rebella
Possibly you should try saving as an ASCII file instead of a Binary. You might also try Selecting Objects rather than DXFing the whole drawing.
Allen
Member
0 Kudos
Post 3 of 7
Re: Compatibility
04-20-2012 12:52 PM in reply to: AllenJessup
Thanks for replying. But it doesn't work.
485 Kudos
Post 4 of 7
Re: Compatibility
04-20-2012 12:58 PM in reply to: rebella
Are you including Civil 3D objects? I don't think that will work. You'll probably have to use EXPORTTOAUTOCAD2004. Then create the DXF from that drawing.
Allen
Member
0 Kudos
Post 5 of 7
Re: Compatibility
04-21-2012 01:24 AM in reply to: rebella
I downloded "autocad_plant_3d_2012_object_enabler_english_32bit" from this page http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17658426&linkID=9240698
But it do not seem working.
Sorry it in french but it say that you have to download an enabler.
194 Kudos
Post 6 of 7
Re: Compatibility
04-21-2012 01:53 AM in reply to: rebella
Forget enablers, because you have only to export 3D geometry (not Civil features) to FEM software like Sap or Ansys.
I feel it will be very hard to shoot your trouble, mademoiselle.
The point is to find a DXF2004 format compatible with your FEM, starting from Autocad 2012.
One possible solution is this one: try and let us know about it.
New Member
0 Kudos
Post 7 of 7
Re: Compatibility
04-21-2012 04:56 AM in reply to: antoniovinci
I'll try upgrading my pc it's too slow :smileysad:
