Distinguished Contributor
bigmaz
Message 1 of 11 (858 Views)
Comparing multiple surface volumes
858 Views, 10 Replies
10-18-2012 08:45 AM
Hey
I have a big hole in the ground in my model.  Its easy to get the volume of cut with C3D.  But I have a topsoil layer, weathered rock layer and then solid rock, I basically need to break them down into different volumes.  The way I would normally do it is calculate the topsoil, then work out the weathered rock and minus the topsoil, then for solid rock cut I minus the topsoil+weathered rock.  Is there a better dynamic way of doing this?  I have attached the 3 volumes I need for info
Joe-Bouza
Message 2 of 11 (822 Views)
Re: Comparing multiple surface volumes
10-18-2012 11:32 AM in reply to: bigmaz
does each  layer have a constant datum?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
neilyj
Message 3 of 11 (816 Views)
10-18-2012 11:53 AM in reply to: bigmaz
Have you tried volume surfaces egl vs total excn model, base topsoil vs total excn, base weathered vs total excn. You will still need to do a trivial calc to compute the topsoil and weathered volumes and the rock volume is direct from the model.
Not sure that this is any better than your current method though but you can produce pretty pictures.
you'd need to create models including the side slopes for each horizon to directly report volumes which is probably more hassle than it's worth.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Joe-Bouza
Message 4 of 11 (805 Views)
10-18-2012 12:01 PM in reply to: neilyj
Thats where I was heading with one twist. If the datums are constants you can tweak the FG build elevation  and one volume surface could be used for the three quantities.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
neilyj
Message 5 of 11 (801 Views)
10-18-2012 12:07 PM in reply to: bigmaz
Looks like a quarry or openpit mine
neilyj
Joe-Bouza
Message 6 of 11 (776 Views)
10-18-2012 08:05 PM in reply to: neilyj
Duh...
Run an alignment through it, sample lines , sections compute materials! ( no extra surfaces required)
Dang I hate when I only think vertically
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
neilyj
Message 7 of 11 (765 Views)
10-19-2012 02:06 AM in reply to: bigmaz
I'll give this method a try although when using it the sample line spacing will need to be tight to minimise errors inherent in a sectional method.
neilyj
Member
AlexanderSchmidtObermoller
Message 8 of 11 (697 Views)
11-03-2012 09:36 PM in reply to: neilyj
If it is a quarry or open pit  then the sectionsmethod is suitable. True, it may generate some kind of minimum error, however the sections are generated automatically and give you the chance to give strictlytrack to the mining and monitors the floor levels.
I have compared the results of the calculated volumes between two triangulated surfaces using sections and other programs as Terramodel, Surpac, Surfer, etc.. The results are very similar.
neilyj
Message 9 of 11 (684 Views)
11-04-2012 08:18 AM in reply to: AlexanderSchmidtObermoller
If the baseline for the sections is dragged and the sections run at 90 degrees to the original line this will give a good check on the volumes - only in a quarry/open pit situation, no good for roads etc
neilyj
New Member
nelson.fava
Message 10 of 11 (267 Views)
06-22-2014 05:48 PM in reply to: bigmaz
I am a beginner in AutoCAD Civil 3d. I went to the fiels with a Total Station and got near 150 points from a small basalt open-pit abandoned mine. I need the following help from you guys: 1) I realized that all the points are 180 degrees rotated around nadir. System coordinates: UTM, datum: SAD 69. Fuse: 22S. How to rotate all the points?; 2) I must calculate the volume extracted from the open-pit mine. What is the method to calculate it in AutoCAD Civil 3D?
Thanks in advance,
Nelson.
