Active Contributor
alegonb88
Message 1 of 3 (121 Views)
Commands not Behaving as Usual
121 Views, 2 Replies
02-06-2014 08:51 AM
Since yesterday, I've been having some "problems" with the commands in Autocad Civil 3D 2014.
I don't know what button I pressed or what did I do, but now, the commands are behaving differently from what they used to do. Now, every simple task I try to perform, takes a longer time.
For example, if I want to copy a polyline, instead of just touching it and pressing "Ctrl+C", now i have to press "Ctrl+C" and then proceed to pick the item.
Another example; if I want to copy the format of an objetct, instead of just touching the object and then pressing the "Match Properties" button and chosing the next item, now i have to press the "Match Properties" button and then chosing the base format and then the item on which I want to apply it to.
Also, I can't use the DELETE key. It's useless. I don't get it. I have to type ERASE every time I need to delete something.
I mean, I can still work, but this gets on my nerve! Hahaha.
My guess: it's probably something really simple to fix.
Thanks for the help!!!
Alejandro.
Valued Contributor
Citadel2012
Message 2 of 3 (115 Views)
Re: Commands not Behaving as Usual
02-06-2014 08:58 AM in reply to: alegonb88
Type "OP" to open the options dialog box, click the "Selection" heading (next to 3d Modeling) and check to see that Noun/Verb selection is checked.
... or type in "PICKFIRST" and make sure it is set to 1
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Active Contributor
alegonb88
Message 3 of 3 (108 Views)
02-06-2014 09:01 AM in reply to: Citadel2012
This forum is great.
Thanks a lot Citadel2012, problem solved, no idea whenever I changed that setting.
Greeting from Costa Rica.
Alejandro.
