Civil 3D Forum
Commandline in the corner and not movable
14 REPLIES 14
Message 1 of 15
burt46
5384 Views, 14 Replies
I have the commandline in the upper left corner as a floating window which autohides. No idea how it happened. Its not clickable, dragable, nothing. If i reduce the C3D window it is still locked to the top left corner of the screen ontop of the windows desktop. COMMANDLINEHIDE doesn´t refresh the situation. I just want my commandline back on the bottom. HELP!!!
Cheers
14 REPLIES 14
Message 2 of 15
Jeff_M
in reply to: burt46
Check that the display/toolbars are not locked, see the lock icon pointed to by the left arrow. If the lock is not visible, you can turn it on using the down arrow icon pointed to by the arrow on the right.
Jeff_M, also a frequent Swamper
Message 3 of 15
antoniovinci
in reply to: burt46
What about toggling CTRL-9 ..?
Message 4 of 15
burt46
in reply to: burt46
All my windows are unlocked and not docked. I tried the CTRL+9 option which is the same as COMMANDLINE and COMMANDLINEHIDE. Nothing seems to work. Here is an image of what my commandline looks like. It fades away after a few seconds. Any other ideas?
Message 5 of 15
burt46
in reply to: burt46
Any ideas please??? Its driving me up the wall.
Message 6 of 15
wfberry
in reply to: burt46
Perhaps until something better comes along, use the "F2" key.
Bill
Message 7 of 15
troma
in reply to: burt46
Perhaps try holding down Ctrl key while trying to drag it.  Holding Ctrl alows you to drag a locked window/toolbar etc.
Mark Green
Working on Civil 3D in Canada
Message 8 of 15
burt46
in reply to: troma
With the F2 key i can resize the window but cant drag o even select it. Ctrl and drag doesn't work either. Think i need some help from an Autodesk employee.
Message 9 of 15
prodigymjb
in reply to: burt46
Were you able to figure this out?  I have the exact same problem.
Message 10 of 15
doni49
in reply to: prodigymjb
Can you give us a screen shot of your desktop?
Press PrintScreen (one of the keys normally found near your "Home", "Insert" keys amongst others).  This will put a picture of everything that's on your screen on your clipboard.  Now go into Paint (Start>All Programs>Accessories>Paint) and paste the image in then save it as a PNG file.
Attach the resulting image file to your message.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 11 of 15
prodigymjb
in reply to: doni49
screenshot attached
Message 12 of 15
jtelder
in reply to: burt46
I "lost" my command line and this got it back. May work for you....
http://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
JT
Message 13 of 15
Just near the bottom at the ribbon click workspace switching > customize option. Left side of the window should have Civil 3D default (current) highlighted. And on right hand panel expand - palettes > command line and change the settings show -yes | orientation - bottom.
It will get it at the bottom of the screen as always.
Sahaj
Message 14 of 15
Thanks Sahaj
Just what I was looking for as well.
Message 15 of 15
You have made me a very glad person with this solution.
this solution is spot on. thanks
Rail Community
