I have the commandline in the upper left corner as a floating window which autohides. No idea how it happened. Its not clickable, dragable, nothing. If i reduce the C3D window it is still locked to the top left corner of the screen ontop of the windows desktop. COMMANDLINEHIDE doesn´t refresh the situation. I just want my commandline back on the bottom. HELP!!!
Cheers
All my windows are unlocked and not docked. I tried the CTRL+9 option which is the same as COMMANDLINE and COMMANDLINEHIDE. Nothing seems to work. Here is an image of what my commandline looks like. It fades away after a few seconds. Any other ideas?
Perhaps try holding down Ctrl key while trying to drag it. Holding Ctrl alows you to drag a locked window/toolbar etc.
Mark Green
Working on Civil 3D in Canada
With the F2 key i can resize the window but cant drag o even select it. Ctrl and drag doesn't work either. Think i need some help from an Autodesk employee.
Can you give us a screen shot of your desktop?
Press PrintScreen (one of the keys normally found near your "Home", "Insert" keys amongst others). This will put a picture of everything that's on your screen on your clipboard. Now go into Paint (Start>All Programs>Accessories>Paint) and paste the image in then save it as a PNG file.
Attach the resulting image file to your message.
Don Ireland
Engineering Design Technician
I "lost" my command line and this got it back. May work for you....
http://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
Just near the bottom at the ribbon click workspace switching > customize option. Left side of the window should have Civil 3D default (current) highlighted. And on right hand panel expand - palettes > command line and change the settings show -yes | orientation - bottom.
It will get it at the bottom of the screen as always.
