Anyone else have this issue?
In the middle of working in C3D 2015, the command line just stops responding.
You can place the cursor there and type away and nothing shows up. If you type a valid command and press enter, nothing happens.
Other commands (toolbars, ribbon, etc.) execute fine although the command line does not respond to them either. So a command like QSAVE works, but you can't use a command that requires command prompt interaction (such as PEDIT)
At first I was shutting down C3D and restarting, but the last couple of times I was able to minimize C3D, move it to another monitor, then move it back and it started working again. I would not have posted anything about it, but this has happened a couple of times a day since I've been using 2015 now.
DYNMODE = 0
Command line is docked
Same config I've had for years and I've never seen this happen.
Solved by HQGL01. Go to Solution.
RK,
I don't have 2015 so I can't test it here. But I *did* experience this in 2012 just a few weeks ago. I rebooted my pc and all was well again. I haven't seen it happen since then.
Don Ireland
Engineering Design Technician
It's true.
It's happening to me too.
I allways have the second dwg open and I interchanged between.
It's more easy then close the dwg and opened again.
Good luck.
Thanks. I see what is happening now. The command line input is partially occurring in a background drawing, instead of with the drawing that has focus.
Switching to another open drawing and then back to the original drawing seems to be a good workaround for this issue.
YES. Anyone find a solution other than closing/reopening drawing/program?
Has a solution for this been found? I recently installed 2015 and started having this occur several times a day. It's becoming a bit annoying.
I don't know if this is a constant thing but when I switched to my other opened drawing, I noticed that a command was in action. So I pressed escape to end it and when I returned to the first drawing the command line was responding again. Will try and notice next time to see if this would be the culprit of the issue.
As Randy (RK) said, just change to another drawing and back again. It is easy, just use the tab to another drawing and back. (If you don't have another opened, just make one).
Bill
ABonell,
I think I actually have an answer to your Type A Brain, well for me it actually worked, as I saw this solution in another post. I just have to type the command LEVELOFDETAILOFF and it should do the work. Although this command is supposed to make your drawings to regenerate faster, I don't think that the time saved with this command can compete with the annoyance created by the a/m problem.
Hope this helps you!
GL
I have also the same issue.
I hope this is fixed in 2016.
We were discussing this phenomenon in a different thread, but I need to add that something that I learned while documenting this problem.
Not only does my command line suddenly stop responding to keyboard input with no explanation, but also my capabilities to make a selection, toggle a switch and click a button fail by mouse input. The responsiveness to both keyboard and mouse returns after tabbing to the next open drawing, and tabbing back.
The suggestion to activate the LEVELOFDETAILOFF command indicates another failure of Civil3D to live the dream. And the official response from Autodesk is to limit the value of its product with this command. The silver lining, your post is referenced in the official response. So at least we know they are aware of the issue.
I am using C3D 2016 and have the same problems.
It's not a fix, but if you go to Options --> User Preferences and toggle between Keyboard Entry and Keyboard Entry Except Scripts, it allows you to enter commands on the command line and saves you from getting out of the file.
As mentioned in a couple of posts above, this can be solved by disabling LEVELOFDETAIL.
Not saying what you said won't work, but if LEVELOFDETAIL is off, it won't happen to start with.
I'm not sure if this is the same issue, but when I was typing in "adcenter" into the command line, it would accept it (aka not show the "unknown command..." message) but the Design Center window wouldnt pop up.
I just realized now that for some reason it decided to dock itself instead of popping up as a normal window, so make sure you look where you have toolbars (like properties and external references, etc.) docked and it might be there already, thats why its not popping up.
Just a thought.
