Joel Harry wrote:
> This does not seem to be a Dynamic Input On/Off problem. Actually turning off DYN makes things even worse as far as typing in the keyboard shortcuts.
> However, I think I may have nailed down the problem...maybe. I'm running 06 on a laptop and I've only got 768 MB of RAM (Pentium IV, 2.66). After seeing that the min. requir. are 1 Gig, that's the only reason I can think of that would cause slow input feedback.
> When I have DYN turned on, typed in commands will actually input correctly. It's just that using the spacebar as return in DYN mode is ineffective (have to hit space bar twice instead of once to execute the command).
You can monitor memory usage in Windows by invoking Task Manager and
switching to the performance tab. Are you running out of memory
according to Windows?
If you can toggle DYN and see a change in behavior, I doubt that limited
memory is the culprit.
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
