Civil 3D Forum
Command line history oddity
8 REPLIES 8
Message 1 of 9
neilyj666
666 Views, 8 Replies
My command line history is aligned to the right rather than left - any ideas how to get it back?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
8 REPLIES 8
Message 2 of 9
AllenJessup
in reply to: neilyj666
I think there must be a way. I've even seen center justified. But I haven't been able to locate a setting or variable to do this. Unless it's inheriting a Windows setting.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 9
I'm experiencing this as well with vanilla AutoCAD 2014 on Windows 8.1. Can't find any options or system variables that would control this... It doesn't happen in my Civil 3D or Map 3D though!
Message 4 of 9
This is infuriating. This has at least two user experience flaws:
1. Split attention, between command prompt and it's history
2. Shifting target, command history changes position based on the length of the line of text (ie, a non-relevant artifact)
Message 5 of 9
architectOfIdeas
Well said.
Message 6 of 9
in reply to: architectOfIdeas
For now, i've just dragged-up the height of the command-line.
This effectively reverts back to classic style, permanently showing lines of command history, but at least it's left justified!! <sigh-of-relief>
Alternatively, if folks really want the fancy fade-out history, then snap the command palette to the right side of your screen, This will help your eye find the alignment edge. A subtle improvement, but better than having it float aimlessly in the middle of a viewport.
Message 7 of 9
architectOfIdeas
can you post a screenshot?
Message 8 of 9
Message 9 of 9
architectOfIdeas
Thanks for posting these!
I didn't realize you could drag the top of the frame to get the classic form factor back!
Rail Community
