Hi, can anybody tell me why command line sometime does not react when I type something? That happens even if I click on her and start typing. It is realy anoying and solution is to change windows few times between different dwgs then it starts to work normally.
Solved by Civil3DReminders_com. Go to Solution.
It appears to be a known problem by other users http://forums.autodesk.com/t5/autocad-civil-3d-general/command-line-stops-responding-2015/td-p/51408...
