Can you set the Command Line to Auto-Hide? I know I can set the transparency down to 10%, but Auto-Hide would be better.
Dave
Dave Stoll
Las Vegas, Nevada
Jay,
Thanks. I've been using Ctrl + 9, but I miss things when the command line is off. I would like only the text lines to auto-hide, and it used to do that after a delay of several seconds. Nothing happens when I right-click the grey bar. I can only click the "X" or the Wrench.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks, Jay. I'm glad to know it's not just me.
Dave
Dave Stoll
Las Vegas, Nevada
neilyj (No connection with Autodesk other than using the products in the real world)
Neilyj,
Tried that. It doesn't seem to change anything. The number of text lines remains the same.
Dave
Dave Stoll
Las Vegas, Nevada
Did you try setting to 0?
Neilyj,
Yep. I tried numbers from zero to 20, and I'll be darned if I can figure out what that setting changes.
Dave
Dave Stoll
Las Vegas, Nevada
My last shot - try increasing the width of the command promt window so the text fits on one line (in the screenshot the promptlines is 0)
and then back to 3
Neilyj,
Well, thanks for trying, but I went back and forth between zero and 3, and nothing changed.
I'm going to dig up 2012 and see if the auto-hide worked on that version.
Dave
Dave Stoll
Las Vegas, Nevada
2012 lets you Auto-Hide the Command Line.
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave,
You can't Auto-hide in 2014 but you can change the transparency to clear except when you roll-over it then it turns solid.
JD,
Thank you. I'm using 2016, and I do as you say, keeping it almost completely transparent unless I roll over it with my cursor.
Dave
Dave Stoll
Las Vegas, Nevada
To only show command history translucently and temporarily and according to your input history lines setting, you need to reduce the vertical size of the command line to its minimum (so only the command input line, the one in white, is showing).
I would still like the autohide feature on new releases but, oh well.
