Jmarugg
Message 1 of 25 (1,775 Views)
command in progress error when plotting by window
1775 Views, 24 Replies
04-17-2012 10:34 AM
This is a wierd error. When plotting by window a command in progress error would display and not allow me to do anything. I fould that hitting the ESC ket rappidly would get me out. Considering how throughly fustrated I was, I figured out what was causing it. Its the scroll wheel. There is there some sort of option I don't know about for 2013? If I try and plot by window and use the scroll wheel to zoom it I get the command in progress error everytime plotter settings don't matter. This has got to be a bug of some sort due to the fact that I have tryed it on 2 workstations with the same result. Any Ideas on how to fix it, or should I just wait.
Alfred.NESWADBA
Message 2 of 25 (1,774 Views)
Re: command in progress error when plotting by window
04-17-2012 10:38 AM in reply to: Jmarugg
And what release of Civil3D are you talking about (and what servicepack)? I had this error, yes, but it's long time ago I got it the last time, maybe 2009 or 2010?
- alfred -
Alfred NESWADBA
Jmarugg
Message 3 of 25 (1,773 Views)
04-17-2012 10:40 AM in reply to: Jmarugg
C3D 2013 x64. No service packs have been released that I know of.
Alfred.NESWADBA
Message 4 of 25 (1,765 Views)
04-17-2012 10:47 AM in reply to: Jmarugg
Window in modelspace?
Window in paperspace?
What mouse driver do you use?
Just in one drawing or also in new drawings (started from an original Autodesk-template)?
We need to know where to start trying :smileywink:
- alfred -
Alfred NESWADBA
Jmarugg
Message 5 of 25 (1,763 Views)
04-17-2012 10:54 AM in reply to: Alfred.NESWADBA
Window in modelspace? YES
Window in paperspace? Not tryed
I tryed it with 2 differant mice both using Microsoft driver on 64bit. I also tryed it on a x32 verison of C3D 2013 and had the same issue.
Happens in all DWG's new from our template or from the plain acad.dwt.
Alfred.NESWADBA
Message 6 of 25 (1,758 Views)
04-17-2012 11:16 AM in reply to: Jmarugg
confirmed for Civil3D 2013 German. ;(
The steps to reproduce:
  • avtivate modelspace
  • start command _PLOT ==> plot-window comes up
  • set plotter
  • set paperformat
  • change to option "Windows" ==> plot dialog hides and AutoCAD asks for the first window-point
  • now use the wheel just one small turn ==> you see in the command-line the problem with "command is active" (translated from german)
  • pressing now <ESC> twice brings you back but a corner seems to be selected.
  • When you turned the wheel a lot more, you have to press <ESC> a lot of times to come back.
But I have to say that I didn't use plot from modelspace for years now,
I also didn't use plot with option "Window" for years now.
That said I tried also plotting from layout and this time using option "Window" for the plotting area ==> no problem at all.
Sorry, - alfred -
Alfred NESWADBA
Jmarugg
Message 7 of 25 (1,756 Views)
04-17-2012 11:46 AM in reply to: Alfred.NESWADBA
We at my company use it a lot for plotting out small sections of a project on 8 1/2 x 11 paper for field crew to use. Its a lot easer to carry then a full plat when your looking for control or just neet to check a few things.
wfberry
Message 8 of 25 (1,745 Views)
04-17-2012 02:36 PM in reply to: Jmarugg
I have always had best results by not loading any mouse drivers.  Let Windows do it.  But I don't use any fancy smancy mouse operations.
Bill
Alfred.NESWADBA
Message 9 of 25 (1,743 Views)
04-17-2012 02:46 PM in reply to: wfberry
Hi Bill,
I haven't installed any special mouse-driver and yes, I have the original Win7-driver (just this) installed, no special button-assignment-16-button-5-wheel-and-whatever-specials-exists driver :smileywink:
And I'm also having the issue with modelspace-window plotting and mouse-wheel-zoom. :smileysad:
- alfred -
Alfred NESWADBA
Active Member
Arfman
Message 10 of 25 (1,713 Views)
04-24-2012 12:23 PM in reply to: Jmarugg
I can also confirm this issue.
I downloaded and installed C3D 2013 on my machine (64bit Windows 7) and everytime I scroll in the select window command under the plot dialog box I get the error.
I also had to set the command line transparency to be the same for both normal and when hovered over. When the second is set to a less transparent setting the command line flickers between the transparencies when I enter commands.
I am holding off installing C3D on the other machines in my office because of this plotting issue.
