I am getting an error every time I type a command, that looks like this:
Command: RG
REGENALL ; error: no function definition: WM:COMMAND-WILL-START
no function definition: WM:COMMAND-WILL-STARTRegenerating model.
; error: no function definition: RSI:COMMAND-ENDED
Is there any way to get rid of this?
Thank you
Do you get the same thing when you type "regenall" for your command? I assume that RG is your alias for the Regenall command. Try this command "_regenall". Notice the leading underscore and see if that works.
Bill
Yes, I have changed some of my aliases but it was giving me the error before as well. I typed in the regular command and it does the same thing. See below.
Command: regenall
The command still works. I just have no idea what the error is.
It comes up for every command I type, not just regen.
Command: _REGENALL
Command: COPY
Select objects:
Command: *Cancel*
OK, since Jeff is the odds on favorite EXPERT here, you need to revisit his explanation and perhaps see what is "behind the green door".
Bill
If it's EVERY command. I'd go right for a repair.
Allen Jessup
from my nook tablet
Allen Jessup
CAD Manager - Designer
