Distinguished Contributor
Rainman1
Message 1 of 2 (509 Views)
Command Alias/PGP File
509 Views, 1 Replies
09-25-2012 10:38 AM
We are running C3D 2012. I have installed C3D 2012 on a new system. When I type "L" in the command line it brings up "Laycur" as my first choice in the Autocomplete list. On all other systems we have, when you type "L" in the command line, Line is the first choice in the Autocomplete list. I want "Line" to be my first choice in the list, how do I change this???? I suspect it has something to do with th acad.pgp file. Thanks in advance.
tcorey
Message 2 of 2 (504 Views)
Re: Command Alias/PGP File
09-25-2012 10:58 AM in reply to: Rainman1
On the Express tab of Ribbon, in the Tools panel, pick Command Aliases. Be sure there is an entry for L and that it's set to Line.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
