Hi All,
I was wondering if there is a preference, or need, of importing Raw Survey Data with Descriptions as either Space or Comma Delimeted into Civil 3D 2013? All of my Figure Prefixes and Linework Codes are configured and will completely import as Comma Delimeted PNEZD, but will not when imported as Space Delimeted PNEZD. Specifically with Space Delimeted PNEZD, my Figures will neither close with the CLS Special Code nor Offset with the V & H codes. For example, the following PNEZD Comma Delimeted will Close the BLDG Figure:
11,4020.0000,4020.0000,110.5200,BLDG B
12,4020.0000,4080.0000,110.5200,BLDG
13,4060.0000,4080.0000,110.5200,BLDG
14,4060.0000,4020.0000,110.5200,BLDG CLS
The following Space Delimeted PNEZD file will not close between Pts 11 and 14:
11 4020.0000 4020.0000 110.5200 BLDG B
12 4020.0000 4080.0000 110.5200 BLDG
13 4060.0000 4080.0000 110.5200 BLDG
14 4060.0000 4020.0000 110.5200 BLDG CLS
I'd really prefer to use Space Delimeted - is there something that I'm missing?
Thank You in Avance,
Doug Bennet
Solved by mathewkol. Go to Solution.
