SSAuburn
Message 1 of 4 (2,431 Views)
Combining Surfaces to create new
2431 Views, 3 Replies
10-02-2012 06:10 AM
Hey,  I'm trying to combine two surfaces to make one.  I saw lots of people saying create new surface and paste the two in the new surface.  Is there a way to create a copy besides doing the copy base, because that keeps causing my AutoCAD to error.
Thanks!
Create new surface, and under the Definitions, right click on Edits for the new surface is paste surface. Select the surfaces you want to paste.
Valued Mentor
Valued Mentor
sjg
Message 2 of 4 (2,426 Views)
Re: Combining Surfaces to create new
10-02-2012 06:19 AM in reply to: SSAuburn
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Jeff_M
Message 3 of 4 (2,425 Views)
You don't use Copy to paste surfaces into a new surface. Instead, create a surface, expand the sutrface in Prospector, go to Edits, right-click, select Paste Surface, here you be able to select the surface to paste.
Joe-Bouza
Message 4 of 4 (2,424 Views)
Why do you need a copy? pasting the surfaces uses the data from the originals and maintains a dynamic connnection.
Pasting A & B into C. If A or B change C will see that change. If you make copies I dont think changes to A will be reflected in A copy
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
