Hi Everyone,
I am creating my Final Grading surface with from 2 surfaces - a proposed road surface and a proposed grading surface. (Note of roads within the road surface)
The issue is that when I paste the proposed road surface (that consists of several looped sections) over the proposed grading surface, the proposed grading surface within the looped road areas dissappears.
I have tried several options using boundaries for the inner looped areas on my road surface, and has altered my order of opterations for my final surface edits, and many other things also.
I have attached an image for your reference.
Any ideas would be greatly appreciated.
Thanks.
Rob
If the roads were created with separate corridors (and, hence, separate surfaces from them as well), you can paste each surface individually into the proposed grading surface without creating the voids.
Other methods will work but are considerably more labor intensive.
The only foolproof way I can think of is to split up either the roads or the grading surface to multiple smaller surfaces, then paste together onto the finished grade. (Paste the big one first, then the multiple small ones.) Either way will work: split the roads up so they don't loop, or split the grading surface up so it fits inside the loops.
As said earlier, this is labour intensive.
Mark Green
Working on Civil 3D in Canada
whatever grading or spot elevations or contours that where used to add to the grading surface, add them to the road surface instead and have one surface with no need for pasting.
This didn't make any difference - I tried several orders, which all had different effects, but none of which were benificial to sovling my problem.
I think this is one for the wish list.
Ideally you should be able to add a hide boundary to your roads surface (possibly you already have one there) and then when you do the paste it should leave the original data in that hide location. This is what you tried first of all, right? And it doesn't work? Instead it is replacing data with no data, if I understand you correctly.
It should work as you wanted it to, I can't think of any reason why not. What do others out there think?
Mark Green
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
